Scraper Shaper
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=5705
Author:  Red Ennis [ Fri Mar 17, 2006 5:25 pm ]
Hi, I bought a scraper and barnisher from Stew-Mac, when you put the hook on the end of the scraper can you actually see it? If you can then I must be doing something wrong or I need my glasses checked. Please tell me what I'm doing wrong, thanks, Red
Author:  RichB [ Fri Mar 17, 2006 5:47 pm ]
I'm not so sure if I can see it either, my eyes are slowly slippin' away. I did have this stored away on my computer for reference. I hope it can be of some help?
http://www.brendlers.net/oldtools/scraping/scraper.htm#EdgeP reparation
Author:  Scott Thompson [ Fri Mar 17, 2006 6:04 pm ]
The hook is miroscopic, but you can feel it. You'll know it is their because you'll get shavings instead of sawdust.
Author:  Martin Turner [ Fri Mar 17, 2006 11:39 pm ]
You should be able to catch your nail on the hook if you run your finger along the scraper.
Cheers Martin
Author:  Miketobey [ Fri Mar 17, 2006 11:55 pm ]
VERY gentlty, if you run it along the length-if you get a great hook drawn,it's like a razor. I gently run the pad of my thumb across it,checking along the length,
Author:  dgalas [ Sat Mar 18, 2006 4:49 am ]
I second the comment on Boggs. Actually, if anyone gets a chance to take a
class from Brian (I've taken two) I HIGHLY recommend it. The guy has
amazing knowledge of most things related to woodworking. How does this
relate to guitars? Well, I always play while sitting in the chair I made in
Brian's class!
Author:  MATTRIX72 [ Sat Mar 18, 2006 1:40 pm ]
JUST BEAT IT WITH A HAMMER...............NOT REALLY DAD
Author:  Serge Poirier [ Sat Mar 18, 2006 1:51 pm ]
Hi Matt and welcome to the OLF!
Author:  old man [ Sat Mar 18, 2006 3:25 pm ]
Hi, Red
I've got the burnisher from StewMac. It works really well, but it took me a few tries to get a good hook. After you draw out the burr you have to increase the angle quite a bit to make the hook. Once I found the right angle it became easy to get a good hook.
Author:  wyodave [ Sun Mar 19, 2006 10:17 am ]
Hey, that burnisher looks like a knife steel(you know for straighting an edge). Can you use one of those???
